WTB: RPM Sport springs
speed23
Anyone have RPM sport springs that they are willing to sell? I only wanna drop the car .5 inches so I can still manage in winter and these are the only springs with such a small drop. Thanks
Try tein h techs the drop is minimal ride is smooth, next best option to rpm..
I appreciate the suggestion. I just looked into them, but it looks like the front drop for those springs is 1.7 to 1.8 inches which is one of the lowest springs I've seen. Unless I am wrong?
Thought it was 1.2 maybe 1.4 not sure.. whatever it is it's not a severe drop for the ms6, the Mazdaspeed and other brands were much lower.. You might have seen the specs for the S techs? Either way they're a stock style riding spring you can find for cheap. They're for sale used here somewhere?
Also they make a wagon version and a sedan v6 version.. You want the stiffer sedan versions..
I did check for the H tech not s Tech. The rear is barely lowered (like .8) but the front is quite low (over 1.5), at least accoring to the specs....
I appreciate the suggestion though!
yeah, its only suggested because the RPMS are no longer made..
also you really need to add at least .5 inches of rear drop to any spring thats originally made for the reg 6.. because the MS6 has another 300 lbs of drive train in the rear end.. so in effect the drop will be 1.5 all around... ive had 5 sets of springs on my MS6.. the tein Htechs for the V6 were easily the best for street driving.. if you want any kind race setup, coilovers are needed.. springs just tease this car!!
Good info!
I am trying to get springs with a higher spring rate than the stock speed6 springs, which probably eliminates most of the springs designed for the regular 6. Seems that the perfect springs for me are the RPM sport....too bad they dont make em anymore...oh well, maybe someone out there has them and are willing to sell.
Bump....I am still looking for RPM sport springs. If I dont get any in a week or so, Ill give up and just leave my stockers on. Thanks.
