civickilla03
Hey every body, I just got a good amount of money from an insurance claim, and with all the damage repaired im trying to put the rest of the money towards boost!
UPDATE: ( I have already purchased some parts, check the list if you have something i need, please)
So im looking to buy:
0. MSP ECU
1. Turbo, GT28R ----------------------------Purchased
2. Wastegate (OEM is internal)---------------Purchased
3. Turbo inlet gasket
4. Turbo discharge gasket
5. After market manifold, with holes not studs
6. Manifold -> Head gasket
7. S-pipe
8. S-pipe -> J-pipe gasket
9. J-pipe
10. Hot pipe---------------------------------already purchased
12. Intercooler-------------------------------already purchased
13. Cold pipe---------------------------------already purchased
14. All couplers for the intercooler pipes--------already purchased
15. Blow off valve or Bypass valve--------------already Purchased
16. Oil feed line-------------------------------already purchased
17. Oil return line------------------------------already purchased
18. Water feed line
19. Water return line
20. Water feed rubber connection
21. Water return connection
22. Water feed -> turbo metal connection
23. Turbo -> water return metal connection
24. Oil feed -> adapter plate fitting-------------already purchased
25. Oil return oil-pan fitting---------------------already purchased
26. Oil adapter plate
27. Oil feed -> turbo fitting---------------------already purchased
28. Turbo -> oil return fitting-------------------already purchased
29. Turbo oil return gasket----------------------already purchased
[list from: neox.286 "Get you started Thread"]
Every piece counts, if you have a piece not on the list you might think i want, pm me.
And im open to suggestions.
0. MSP ECU
7. S-pipe
9. J-pipe
18. Water feed line
