Wonder why your engine keeps blowing up?
My car falls in the VIN range but mine has a production date of 2/08. My local dealer said it still applied to my car still, I haven't driven it enough to see if any of the symptoms are constant so I guess I'll wait until more info is available.
I was at the dealer and my invoice says PCM recalibrate which I am assuming is the reflash you guys are talking about.
It also says (actuator inspect only) and (PORT) is any of this the fuel pump inspection you all are talking about or do I need to go back?
O NOES!!!
Just went to my appointment for the TSB, I am having the idle problems. They blamed my aftermarket intake and would not check the fuel pump :(
The did do the other recalls that were required though! I will remove the intake, bring it back to them, and let them have another shot I guess...
Dave
