3Wheeler,
You can't have both an awesome "ultra high performance" summer tire and winter tire in the same package. Thats technically impossible.
The main reason for this is the type of compounds used for each tire type. Winter tires generally use a compound which grips best when temperatures drop below a set degree, usually around 45F or lower. Summer tires do the opposite, they grip best in the upper temperature range and generally have a higher heat ceiling then general or all-season tires.
All-seasons tend to try to both be the same type of tire at the same time, sacrificing grip in both situations for increased ride comfort and noise levels.
I am not debating that your winter tire selection isn't good...by all reports its an excellent tire. I am just pointing out it in no way shape or form compares to a dedicated summer tire. It at closest aproximation matches a decent all-season in lateral stability and dry grip. And by reviews, does outperform the MX4 mich's...but then of course, so does half the tire market
