Windshield wiper replacements don’t fit
Anyone else had this issue? I bought two different types of blade (Bosch at Advance Auto parts, Rain-x at Walmart) that said they were correct for my 2021 Mazda CX-5, yet the attachment that is supposed to work for them does not fit. Now I’m out like $80 and still have a two busted blades that barely work. I had no such problem with the rear blade.
You want to buy blades that use the "top lock" adapter, not the normal J-hook style. I think the Bosch Icon is one that will work, and I think there are some Napa and/or Trico blades as well, just have to make sure they have the top lock adapter.
That said, it's a lot cheaper (usually) to just buy replacement rubber inserts. Pull the old ones out, slide the new ones in. I just replaced the ones on my CX-9, and up here in Canada they were $15 each (used to be like $8 to $10).
For winter, I use Bosch Aero Twin blades (code A398S), which are available on Amazon. During the other 3 seasons, I stick with the OEM blades.
Ask the dealership. They have to versions of wipers, both OEM, one is cheaper. Ask for that one. Wiper blades, not inserts.
Yes go with the OEM inserts. Super easy and best quality last long although ice chewed up one after a harsh winter but just replaced it again
ditto. literally just installed new oem inserts and super easy.
