a windshield should not crack out of the blue. i can understand if a rock hit it but there is no spider crack whatsoever.NoVaMSP said:doubtfull , if it took over a year to crack i wouldnt call that a defect . could of happened
from a number of things
laracroft said:How long have you had your car because they might use that as a factor? The crack looks like it actually branched off. A rock will not usually cause a crack to look like that. It may very well be a defect or some other object that caused it.
Worse case scenario = car insurance will cover it. Sometimes free of charge or you may have to pay a $50 deductable. Check with your local speed mechanic about it being a defect, then check with your insurance agent about your coverage. I would not mention it possibly being a "defect". If you find that the dealer will not cover it, tell the agent it was a rock. lol
i did this and there is no point where anything was hit with a rock or object. it is clearly a stress crackjeremyfl said:Take a ball point pen and run it up and down the crack if it stops anyplace then something hit the windshield (when I had my mazda6 and the windshield cracked thats what they did at the dealership because i thought it was stress fracture, sure enough at the very bottom of the windshield it dipped and we could then see where the rock hit, called insurance company and they fixed it the next day with no deductible. Thats the law here in FL at least).
Yeah, same thing happened to me. Just found a crack all the sudden one day. Mazda would not replace it. There is a spot where it is chipped, and I was thinking the same thing about how glass tends to chip when it breaks.wicked said:I got to school at 1:00 car was fine,came out at 5:00 crack half way across my window.
they did the pen test,and sure enough the pen hit.but if you look at were it hit,it's not cuase of impact it's cause when you brake glass it sometimes chips.
on the other side of my window you can se a impact,but it's not cracked or spiderwebbed.
and no mazda didn't replace it.
my insurances doesn't have free windsheild replacementb00sted said:your insurance should replace it for free..mine did
