Do you use the same magnets for track days? I lost one of my magentic numbers the last time I was at Mid-OhioI still need to get a replacement.
To AJ's comment I'd think magnets would be worse for paint than vinyl stickers.
in what world are magnets worse....
Oh man, I just realized you use the number 4. Not that we'll ever been in the same event anytime soon but I always ran as "04" at NASA events. I lost one of the zeros so now I'm "4" too.Yeah I typically use just the number 4. The "Mazda" and "Toyo" magnets I'm just running this weekend for contingency in the unlikely event that I end up in the top 3 in class.
But yeah I use 30 mil magnetic sheet so they aren't coming off at speed.
This is what I was getting at. The possibility of getting crap between the magnet and the paint just seems higher. Also, if something does get in there the heavier magnetic would want to push it into the paint more so than vinyl, right? Either way, like you said if you're careful about it it shouldn't make a difference. Don't magnets weigh more???It all depends how anal you are about your paint. There is no way to ensure the back of the magnet is going to be clean enough to not harm the paint at least slightly. I have some swirl mark type scratches from where I always put my autocross numbers. But, they polish right out with some wax or polish.
Vinyl isn't going to move at all once it's applied. You just have to deal with the adhesive if/when you remove the sticker.
I have no idea what I'm doing but your runs looked really good to me. There was a couple times in the slalom I was like "Oh snap! That cone was close!". haha.
And the BRC vinyl looks badass. And so nice and straight too!
Miata owner burn!?!?!
Thanks Evan.
I messed up a few times on the first run in particular. 0:53, 1:03, and 1:35 were all instances when I wish I would've turned in a little sooner and got closer to the cone(s) on the inside.
I took the BRC vinyl off as soon as I got home, and it came off easily! In fact, I think it was better than my magnets which had all kinds of gunk under them from running in the rain on the first day.
