will these winter tires/wheels fit?
yes and yes
205/50 right?
I run a 215/50 on a 17 with the same offset and do not rub. I am at the lowest setting on BC coilovers.
205/50 right?
correct sir. thank you.
just wanted to make sure, because when you look for tires for the speed3 it only shows 18" and above for some reason. so I just checked for the regular mazda3 and that combination came up.
