Really? So anybody can just get the AP, read the manual overnight, then next day "tune" the crap out of the car and then a couple of months down the road, you hear engine detonation like there is no tomorrow... oopppssss I guess you just forgot to change a variable in the tuning and now your engine is on life support... I know this is an exaggeration but so is this statement above... especially coming from a vendor. I am sure they only sell AP and don't carry HT. I wouldn't call this an "unbiased" opinion...! In essence, the AP is NOT for everyone... Not everyone has the skills to tune the car SAFELY...especially with DI...
I have tuned the crap out of my Turbo Miata with Flying Miata Link and even Tec II. Those are waay more sophisticated than the AP but I got tired of it and now I love the simplicity of the HT on my DD. If I ever decide to go BIG Turbo (I doubt it) then the AP will be my option.
AP vs HT... When will this end? (deadhorse
LMAO. If you tune the car, and everything is good, you don't just 'develop' detonation down the road, it doesn't appear out of nowhere unless you use s*** gas, and if you do that, it's not the tune's fault, it's your own. Also, the accessport does it's own datalogging of all possible params, well more than I had in my log above. But hey, if you tune it, run a datalog to check the tune, and see kr, then you go back, pull back on the timing, and you're fine. Oh, and if there is severe knock, the ECU pulls timing by itself to prevent detonation.........you know, because it's sophisticated. But I'll talk sophistication later. Regardless, someone doesn't need to **** around with ignition timing to make decent power on stock turbo with pump gas. Use an OTS map, do a couple MAF calibration logs. Calibrate the MAF, set AFR targets to 11.8:1 or 12:1, up the boost and wastegate duty cycle to hold boost on the factory turbo to redline better (only the '11's and '12s so far seem to hold more than 20psi to redline.....turbo upgrade we think) and you've already made leaps and bounds in gains over the HT. And you haven't touched ignition timing or VVT, or anything else, really.
Tec II more sophisticated than the FACTORY ECU in the Mazdaspeed? You pretty much just blew your credibility on mazdaspeeds right out the ******' window. AP isn't the control of the car, it's a reflash/tuning tool that allows you to flash tunes to certain tables on the factory ECU, and not even all tables as Cobb is constantly working on getting access to more tables as it sees fit for users and as they further crack the ECU. Does the TEC II handle a direct injected car running fuel pressures at/above 1600psi at WOT? With individual coils per cylinder allowing ignition control DOWN TO THE CYLINDER? pshh. Right. And a miata ain't no MZR DISI, so don't even compare them. We're running factory MAF/MAP combo, etc. Tell me, can the TEC II hit specifically targeted air fuel ratios just by calibrating a MAF?
Also, it's obvious you have no experience with the Accessport, but in it's various uses, R35 GTR's are tuned to make over 1000whp via AP. Cobb knows exactly wtf they're doing, and their support of this platform is, frankly remarkable. Accessport has pretty much made tuning something anyone with patience can do successfully.
Btw, I'm not a vendor.
