Reading through this thread has been very helpful. Thanks to all for the great discussion and exchange of information. I am trying to help a friend (with a Speed3) with his tune and I think he is running into the same problems you all are discussing. He recently purchased an AP and loaded the Stage 2+FMIC 93 map. His mods are Cobb SRI, PG Turbo Inlet, PG FMIC, CorkSport Test Pipe, HKS SSQ BPV, HKS Hi-Power Catback Exhaust, and he just installed ITV 22's (he checked the gap before install). He has had all these mods and no tune for at least 6 months, so he got use to his car doing strange things under a variety of load conditions. After loading the Cobb and flashing the map he said that the car was running better, but there was still significant KR. I took it for a ride last night and my impressions were;
1. Much smoother than last time I drove it (5-6 months ago)
2. Pulls hard (to the right if you are not paying attention, torque steer almost caught me sleeping the first time I jumped on it) It was a little bit of a wild ride until I got use to being in a FWD monster again
3. Loosing power WOT around 4.5K, should pull MUCH harder to 6K My current thinking is that he is hitting fuel cut when his car builds 19+ lbs of boost. I think he agrees and said as much last night, but we weren't sure if it was boost cut or fuel cut. After reading a bunch I am leaning (pun intended) toward fuel cut. The big question is, what is causing it. I think it may well be a combination of needing new fuel pump internals, and something in the tune needs to be adjusted, but what?
4. Also loosing power/knocking under less than WOT conditions. Less predictable/repeatable. Not really sure of the cause of this, but I suspect this is also a problem with the relationship between his tune and his mods. Since it is happening under less than WOT conditions I am not as concerned with this since the engine should have no problem protecting itself.
Possible solutions:
1. Tuning out the problem I think this is going to be the best way to go. Fix the tune rather than put a Band-Aid on it.
2. Fuel Pump internals Another friend's idea, and I am thinking he is onto at least some of the problem after doing a bunch of reading, some of it right here in this thread.
3. Using a different map (currently on Stage 2+ FMIC IIRC) Stage 1 maps would drop the boost target and that might fix the problem, although I think it would only be masking it.
4. Some sort of electrical/mechanical fix (EBC, MBC, Boost Cut Defender, Fuel Cut Defender, etc....) Band-Aid, not a good final solution, but could be added for another layer of safety
5. May be temp related. I live in Chicago and he has only had the AP for a few days so it has been cold the whole time. However, I am not haveing the same problems with my wifes MS6 running a Cobb Stage 2+TIHSF tune in the same weather.
Here are a few logs. I tried to name them in a way that makes it easy to tell what you are looking at. It was pretty cold (like 12 deg) when we made these logs. Questions, comments????
