TWM has a short shifter designed specifically for the MazdaSpeed Protege which reduces the throw by 35% and the knob height by 1 inch. Our Mazda Speed Protege shifter also allows use of the stock Mazda Speed shift knob since it is longer than the regular Protege shift knob. They're on sale right now, check it out: Mazda Speed Protege Short Shifter Salespeedfrk said:I Was wondering the diffrences between the diff. Short shifters on the market And the Msp shifter . What are the measurement diffrences in hieght and which are best quality. didnt really find anything good during search ? anyone?
Velocifero said:Let me clear some things up about the 3 main SS available for our car:
1. TWM is the shortest throw distance, and slightly shorter height wise than stock. They also are the only ones using ball bearing bushings and I guarantee you won't find anything better. Customer service is great and they back their product 100%.
2. Kartrboy is a slightly longer throw distance and they are the shortest height wise. Good product, but a lot like stock in design and install. They stopped being a vendor here, but they have always had decent customer service.
3. B&M is the longest throw and the tallest in height, they do replace the urathane shift brackets with aluminum, but they are the hardest to install. I don't know anything about their customer service, being as I have never ordered from them.
Personally, I say the TWM hands down. Great quality and it feels great, the shift is so positive and I get nothing but envious compiments about it. I also have their weighted knob which is nice. I have installed and driven all three options on proteges. Not trying to be biased, since I own it, just giving you the facts as I have researched it. I have two friends that have B&M and want to take them out but it is too much of a pain in the ass. The Kartboy and TWM install just as easy as removing the stocker, except TWM includes spacers to drop the heat shield where Kartboy recommends cutting the heat shield to accomidate.
it can wear out the syncros faster if you beat on it alot.speedfrk said:Thanks all this info is great . How much shorter than stock is the Kartboy? I do like the TWM shifter alot looks really nice. I think I would go with Twm also over the B&M just because its more specific to MSP. Any Negative Draw back to the Short Shifters?
I recently sat in a new STi at the international autoshow and I would have to say that my shifter felt alot like the one they use. I don't really feel a notchiness but it is almost like you can feel it "click" into gear, not hard to get in or out of the gear. Off topic but you know whose shifter I was extremely disappointed in was the new GTIs. It felt like rubber crap, huge amounts of forward, lateral, even diagonal play. I didn't like that at all (I made up the part about the diagonal play).EnjoyMinuteMaid said:do you really think the TWM feels significantly different than the B&M? how about the notchiness?
Essentially our bushings perform the same task as the Kartboy bushings, however we decided to make them out of a slightly softer polyurethane (only 5 durometer points softer) to reduce vibration. The overall feeling is the same once installed in the car, the soft rubbery feel of the original bushing is removed, however there is less vibration than with some other brands of polyurethane bushings on the market made of stiffer polyurethane.EnjoyMinuteMaid said:Are your bushings identical to the Kartboy ones aside from the color? Also, what is up with the ball bearing bushings, and why are they better than the corksport bronzeoil ones? I have never heard of them but I have noticed the rubber pieces of crap that come on the stock shifter and plug into the ball at the bottom for the bolt to go through.
mspHtown said:kevin,
how do you take advantage of the student discount?
thanks
