Which NGK Spark Plug?
2019 CX-5 Signature
OK, just need some clarifications as I seemed to have confused myself :)
I need to change both my wife's plugs (2018 CX-9 2.5L) and mine (2019 CX-5 2.5T). Are these both the NGK 90288 (DILKAR7M8) plugs or does our CX-9 need the 94124 (ILKAR711) ones? I am seeing posts all over the place and both are mentioned.
And yes, I debated which forum to post this in (CX-5 or CX-9)!
As always, thanks for the help!
I think the turbo and the NA 2.5L use different plugs.
I saw that as well, but I have seen plenty of instances where the 2.5L used the DILKAR7M8 plugs without issue.
Hence, my dilemma and confusion :)
Make sure the gap is correct on the plugs before you install! The ones I got from Amazon were completely off! Caused a slight stuttering at low rpm. So were the old ones I pulled out.
