Which Map?
cpspeed6
2007 Speed 6
Ok guys, my parts are here, and I need to know which map to run:
Cobb TIP, SLS Test Pipe, Injen CAI. Denzos are already installed. And I'll probably run 91 Octane for now.
stage 1+sri 91. monitor it for a while, if everything stays within the parameters of the map notes you should be ok
I just put 94 Octane in, gonna run that for a while, so I'm gonna try and find a 93 Octane map that is similar to my mods on mzdspd.
Guys, I got the Cobb TIP, Cobb SRI, SLS Test Pipe, and Denzos installed, and I'm using 94 Octane atm. Which OTS map should I try?
