which map should i use?
djdanny5000
Contributor
2007 Mazdaspeed 6 GT Retired: 2002 Protege 5
so im gonna buy the cobb accessport but im not sure which map to use with my current mods. i currently have the ms cai, su test pipe, and hks bov. what map do you guys think i should use? im thinking stage 1 which they say is for mainly stock. also does any one know if they released the 93 octane maps?
mzdspd.com
i host a lot of maps for cobb. you can try either a stage 1 or stage 2 since you have a test pipe. i think there is a map for the ms cai.
hey bova thanks for the recommendation, i was on your site and saw that there is a stage 2 for the ms cai so ill try that one. thanks man!
i have a similar question, i got the cobb intake, forge bpv, corksport c/b and corksport "race pipe" what map should i be running?
To the OP, check out the Stage 2+MSCAI 93 v102 for your setup.
To 311, check out the Stage 2+SF v103a or v102 and you should be good.
Well i now have a CP-e catless downpipe and inlet pipe and i'm running the Stage 2+MSCAI 91 V1.01 e map or something like that. I tried out the stage 2 TIHMSCAI map but i got a bunch of knock retard and it felt like there was no power at all. I dont think i've tried the stage MSCAI 1.02 map yet though so i'll give that one a try next
Oh, try the Stage 2+TIHMSCAI 93 v102. I'm running that map with really good results right now.
Really? I tried it once and after driving it around ton like recomended for about 50 miles i got on it and my knock retard went up to 5.6 degrees or so and it felt like there was no power. I'll give it another run cause i never actually gave it a chance.
I have a ETS 2.5, Cobb Tip, Cobb SRI, TurboXS Hybrid BOV, Denso 1 step colder plugs, and I'm running on 93 octane. I'm running Stage1 + TIHSF 93 map, but I'm running lean at idle and at cruise. My LTFT's are around 7-8 at those times. Should I try the Stage2 + TIHSF 91 map to see if I can richen up the mixture?
