mazdaspeed562
Thinking about selling my ms3 because pa winters make me nervous, the problem is i dont know what to buy next... i have 20gs to spend looking for something stick shift preferably awd any suggestions???
good snow tires and you'll be fine unless you just want something new/different
The myth that AWD/SUVs are safer is a dangerous myth because it makes people believe that they will be safe no matter how badly they drive.
I've seen a ton more SUVs go off the road in winter weather than any other car and a few Subaru's that have as well.
Bottom line buy some winter tires and drive sensibly and you'll be fine. The only thing you need to watch out for is the MS3's ground clearance, other than that the car is a tank in the snow. Oh and I also turn off DSC in the winter since it tends to get a bit skittish if it hits slippery areas.
the old VW beetles were said to have been the best cars in the snow. reason being because they had plenty of weight on their driving wheels, and the tires were so skinny they were able to contact the pavement better than wider series tires. therefore, it sorta just cut right through the snow
that and there wasn't enough power in that thing to overcome traction so the risk of spinning as soon as you step on the gas would have been less
