Wheel hop when accelerating hard (especially first gear)
also remember that making just 1 mount solid effectively puts more stress on the rest of the mounts which wears them out faster.
If you just do the front mount the tranny will hit the cross bar that the front mount is on. Alot of people say it wont but when I just had the front mm in I would sometimes hear a clunking sound when I went to do my rear I investigated it and sure enough it had been rubbing on that cross bar and that was the sound I had been hearing.
SLS front & side, OEM all others. No hop and and not worn out. 85K miles so far. Don't believe the hype. AWR = rattle ******* trap. Some people like that however.
when i had a solid front, side, and trans inserts, my engine sat crooked in the bay from not having the rear. just food for thought. the rear will add the most vibrations since its closest to the firewall.
I've seen broken SLS mounts, I like my AWR. Rattle trap yes, wheel hop no, broken welds no. They revised the bushing design of the SLS but I still chose the AWR.
i had zero problem when i did my ft mount only.. once i did rear i picked up vibrations.. this was in 06 wheel hop was less once i did my front. now i have all 4..
I had major wheel hop. One of my first mods was the 88 duro AWR Full front MM replacement and side inserts. Vibs for sure increased but not too bad. The stock subwoofer creates more vibs anyways kinda drowning out the motor vibs. The only rear issues I have is sometime the change in the ash tray shakes too bad I just pop open the ash tray a bit and the noise goes away. I do have a Medieval rear mount sitting hear waiting for install. I just don't have the patients to go through all that hell getting it in. I guess as somepoint it has to go on. Maybe spring LOL. Either way all my hop was gone instantly after the install of just the Full front and side inserts
