Wheel help!!
Army248
09 Mazdaspeed 3 GT
I have a ms3 09 and I wanna find out if a 18x8.5 will fit without any issues my car is lowered with tein springs. And will a 225/40/18 tire fit good on that wheel size ....any help would be greatly appreciated!
I would go with a 235/40 tire on a 8.5 inch wide wheel. I'm not even sure a 225 is recommended for that width. You should be fine with at least a 50mm offset for fitment. I wouldn't get any higher on the offset, only lower. +50mm to +40mm will fill the wheel well nicely with that width.
You might need to roll the rear fender if you're lowered though.
