I got a set of Asa gt1 17" with blizzaks from a friend with an 09 evo which has the same bolt pattern, but when I test fit the wheel it still a no go. Am I missing hardware or are these wheels just no good for me? Any help is greatly appreciated.
What is the hub bore? Also i think the evo use a different lug nut style(taper vs washer/flat), which are you trying to use? Are you hitting caliper or just doesn't seem to sit flat on the hub?
