I'm looking for a good setup for auto-xing and possibly track days this season (first with the MSP), but have some concerns regarding clearance. Here's what I'm thinking...
Wheels: Kosei K1 TS 17x7 50mm offset (14.1 lbs)
Tires: Bridgestone Potenza S-03 225/45/17 (25 lbs vs 24 lbs for 215's vs 23 lbs stock)
Will this work or will they rub?
From the spec's on Bridgestone's website, the overall wheel/tire dimensions would be as follows:
.5 inches closer to the outter wheel well
.1 inch closer to the strut body
.2 inches higher on top
.2 inches more on bottom of wheel
The first question is: Will these rub?
The second question is: Does the 225 width give enough of a grip advantage over the 215's to make the possible rubbing and weight penalty (1 additional lb) worth while?
What do you guys think?
