What size of tire?
ElPatron
Hi everyone, Im new here (first post) and Im Mexican so my english is far from perfect. Here we go...
I have a 2010 Mazdaspeed3 and I have already started to "upgrade" some parts:
I bought an AEM CAI (installed).
I have an HKS SSQV3 Recirculating Valve, Cobb Downpipe and Corksport Front and Rear Mount Inserts "in the mail".
Im planning to get a Turbo Inlet Pipe, Hypertechs Max Energy Sport (when it comes out), shifter bushings, a Protege Garage Tubular Turbo Manifold and Denso Iridium ITV22 Spark Plugs.
Ok, as for this thread...
Im not lowering the car, Im keeping the stock 18" wheels that I really like and Im getting a set of Hankook Ventus V12 evo K110.
What I need is to get the most rubber that I can (better grip), better comfort (the stocks Dunlops are very very hard and noisy), if the tire is a little larger in diameter it is going to fill the gap better and at the same time it is going to give me a little more protection from potholes and stuff (we have a lot of this, and also every kind and size of speed bumps that can be very hard on the rims).
So, what size do you guys recomend?. I was thinking 235/40. But you are the experts, I dont know if a 235/45 or 245/40 would fit or be too much. I think the 245s would be way too wide and probably would hit the fenders or something else, they may not even fit in the rims (but Im just guessing...) ...
Remember, more rubber to the ground, better hit protection, a little better filling of the gap, more comfortable, but dont want to go overboard or a size that hits the fenders, something that you guys would do to your own car.
Well too much talking (in this case writting) and Ill really appreciate all of your opinions.
Thanks a lot!.
Welcome!, I cant really help you but you should share some pics in the other forums...
Sometimes replies take some time due to the relatively low number of members in the subfrum...
BTW, did you try a search? maybe youll find something useful... cheers!
(Bienvenido al foro compadre! no te se decir lo q andas preguntando pero comparte fotos y demas en los dems threads... de repente tardan en contestar ya q no hay muchisimos miembros q digamos...
Trataste de buscarlo? chance encuentras algo por ahi...
Saludos!!)
Did you solve your rattle?
Thanks for the post "paisano".
I know that it takes time, Ive seen Threads with hundreds of views and "0"replies. So I replied to myself, jejeje, that whay I put a "1" in the replies count. And it helped a little bit to "jump start" and get some movement. Hey, I got your attention!, thanks again for your comments.
I almost made my mind about the tire size, Ive been asking around (I didnt find anything in the forums) and Im about to order them.
By the way, Did you solve your rattle?, if not, I may have some input that may help you, and in about a week Im upgrading a couple of parts that may solve the rattle that I have in my MS3 and Im almost sure Ive identified.
Saludos!.
