What parts to get
krausean
Mazda Protege5
Hi, I've installed an after market exhaust and have an Air Intake coming.
I'm trying to decide weather to get some headers next or to get an intake manifold. I'm trying to create some easy HP here...lol.
Thanks for any advice!
Header would be more noticable. Consider and under drive pulley to complement the header.
You should consider upgrading your motor mounts too...it will give you less wheel hop, quicker throttle response to the wheels and prevent the engine from torquing on the headers too much.
AWR makes some great front and rear mounts and side inserts. You can do the front mount and side inserts yourself, but the rear mount is tough and you may want to have someone do it, depending on how mechanically inclined you are. They have three stiffnesses you can purchase. Check out protegegarage.com.
Hey thanks a lot guys. How much work is it to install the front motor mounts and side inserts? Does the motor have to come out or can i just lift it up off the old mounts (I have a shop crane). This is my daily driver so i can't have it out of commission for too long. Also if i don't get the motor mounts could i wreck the headers?
Would you recommend these headers? http://mazda3online.web.aplus.net/product_info.php?cPath=281_21_31_46&products_id=459.
The price is right and the reviews are good!
thanks
The side inserts and front mount can be done without removing the engine. I believe that when doing the side inserts you need to support the motor with a jackstand, but the front can be done without that (though I would do it just to be safe). The rear mount can be done without removing the engine, and if you search around a bit you will find that there are a few recent posts about that. I hear it is much more difficult than the sides and front. I have not done a rear mount, so I can't speak for that.
As far as tearing up your header, it will put more stress on the header and exhaust if you don't replace at least the front and sides, as your stock mounts, if not torn already, will be soon. All that play in the drivetrain may or may not tear up your exhaust or header, but it will put more stress on it, so it's better to play it safe in my opinion. Search around the How-To for some directions and tips on installs, and there are some motor mount threads in the Protege5 forum. Streat Unit (actually spelled with two "e"s) AWR and SLS all make engine mounts, and they all have different durometers (stiffness), but AWR and SU are the only ones that makes a whole set and SLS has had several side mounts fail. StreatUnit's mounts are very soft (60 duro I think) but still stiffer than stock.
Remember that with these stiffer mounts you're going to get more cabin vibration from the engine, especially when the A/C is on. Check out the motor mount threads for more feedback. The general consensus is that adding new mounts feels like bolting on 5-10hp due to the recovery of power normally lost in drivetrain lash. A UDP would be a good addition to the header, and I don't know if your exhaust is a cat or axle back, but protegegarage, SLS and Corksport all make midpipes with a flex section (to take stress off of the exhaust and header when the engine shifts), and you can get them catted or without the cat (my preference, but I don't have to pass emissions either!). I hope all the info helps...happy modding!
You also can get a MP3 ECU. Short shifter. JDM Cams. All that put together will work nice.
I have heard mixed reviews on OBX, and I think they are generally not top of the line, but they are a good discount header. There is a header on ebay called Tsudo, and I they cost about the same as OBX and I hear they are similar in design but have a little better build quality. For a little more you could get a thunder header, and protephile sells them on this thread, and I think they are considered a relatively high quality header.
i have the obx header and i have not had any problems out of it for the past two years. yeah it's a little ugly not since all the oil residue and finger prints on the header have turned it purplish but the car still runs great
I guess i'll have to look into those engine mounts now. Never thought they were important.
About the cams...do you need an after marked ECU since your timing is out to lunch after installing them? And what would be a relatively inexpensive ECU...i'm on a budget as i'm sure most of you guys are.
I only have an axle back exhaust system but i think i'm gonna change that to a custom 2 1/2" system before i get the headers. Hopefully that doesn't turn too loud on me...lol
How much better is THUNDER 2.0L PROTEGE HEADER than the Tsudo?
I've not heard a ton of feedback on the Tsudo header, but those who have had it have said it fits well. I have heard good reviews on other Tsudo exhaust pieces. I have heard that the thunder's welds may be a little better, and it comes in two pieces, so it's easier to install.
