I would guess a 4.8 or so 0-60 and a mid 13 sec pass. Something comparable to the Evo or STI.
not even close the 0-60 would go down a good bit, but the 1/4 would go up because of the weight, and drive train losses. in drag racing it would probably be a wash
Srsly?
The MS3 traps right at 100ish, in my old car I ran a 13.3@100. I'd say it would be a solid 13.5 car if you drove it right. Of course this all speculation.
no way my sentra traps 112-113 no matter how poorly I drive it with a passenger that went down to 107-106 also the ET went up a couple tenths. adding 2-300 lbs, and a bunch of drive train loss wouldn't help in the 1/4 at all except 60' times
not as fast as it would take me to go to the dealer to go buy a new one in AWD that's for sure...if they would in fact do it
+1If the MS3 were AWD it would basically be an MS6 and there are stock MS6's running mid 13's.
+1
Good point. Maybe a little faster, but that heavily relies on being able to successfully launch a AWD. I cry a little inside every time some STi/evo bogs out in 1st.
I based my guesses off my old Evo. 271 stock Evo vs 263 for the stock MS3, Evo weighs a couple hundred more pounds than the MS3 but with AWD it would be about the same. Hence the mid 13 sec and 4.8 0-60.not even close the 0-60 would go down a good bit, but the 1/4 would go up because of the weight, and drive train losses. in drag racing it would probably be a wash
