What Is A Good Compression Reading For The Mzr Turbo Engine?
2006 Mazdaspeed 6
Hi guys, what compression numbers should the mazdaspeed 6 mzr turbo engine display if it is in tip-top shape? Just thought i'd check mine and compare it to others out there. Appreciate a response. Thanks.
I don't know the numbers. But, as long as you are within about 5% on all 4 cylinders you should be ok..
