MP5stephen
- Mazda Protege5 & Miata M Edition
Don't beI know how hard it can be sometimes to get something done for yourself at work
I might need some 5mm, or smaller. My question is, wouldn't I need longer wheel studs?
Jigga, something is wrong with your alt and it should be swapped out. But yet you seem to defend that nothing is wrong with it. As you know, rebuilt alternators are always a crap shoot, 1 out of 3 are decent. Swap that puppy out or keep getting asked "Is that thing supercharged?".
It's because he doesn't want to swap alternators for a third time, I'd be super annoyed if that happened to me too.
Any rubbing with 18 inch wheels 215/35zr/18 and eibach spring pro kit? Any other springs I should use instead? Currently I'm on stock springs with 215/35zr/18
depends on the offset, i dont rub with my 18s and coils.
Thanks man, needed to hear that since it's a great deal on the block. Most places around here want around $1200 for a used block. I won't be getting the pistons with it. It's just the block, crank, and head. I think he's got a buyer for the rods and pistons.I believe you are mixing up the fs-ze and the fp-de. The fs-ze should have the same block height, only the fp-de has a shorter deck height, since it has a shorter stroke than the fs-de.
The fs-de pistons should drop in with no problems, let me know if you decide to get the ze, as i will prob buy the pistons off you depending on the condition.
Cleaned up my wiring at the battery terminals with techflex and installed Hella Supertones. Damn they are loud.
i bought mine 3 years ago today![]()
