:) I knew that, I was just testing. Thanks a bunch for the pointer! Now, off to trying to find another job to bring in that $240!!!
Getting Ready for WWIII...
MP5T vs 190 MPH
Carbon Diffuser Design is starting.
Engine and Trans #1 is Coming Out to be rebuilt,
Engine #2 is Going in with a New Clutch and FV
Trans #1 is Getting Taller Gears for 4th and 5th
- 4th Gear (0.725) Taller 3000 RPM = 123 Km per Hour
- 5th Gear (0.625) Taller 3000 RPM - 145 Km per Hour
Awesome!!!
Really all's what you need to is drem out the hub knuckle holes a bit add some 1/2 id washers to each stud behind the rotor (about 3 each) and put one washer between the caliper bolts and the knuckle and its very easy and simple, the stock brake line even bolts in :)
took evo x rims off. back on stockers selling evos tomorrow. want to go with a nice agressive 17s
set up
stockers. might do them plasti dip black for now until i get new rims
Yea those are FDs 16x8 +48 offset. Tires are huge, shoulda went smaller. those are 225/50/16 Potenza REO1Rs
Awesome!!!
Just a follow up on some basic math that was done..
The New 4th Gear will do 155MPH at 6500 RPM and 167 at 7000 RPM
The New 5th Gear will do 180MPH at 6500 RPM and 194 at 7000 RPM
In 5th Gear at 66 MPH, the engine will be turning 2200 RPM when just driving normally...
I will likely have to be in 4th all the time unless I am over 80 MPH.
4400 RPM at 120 MPH... Which can easily be sustained without any worry of damage to any engine part..
Finished wiring in one sedan light, one more to go, hopefully tomorrow. It's amazing how much more light is put onto the road from a brand new headlight compared to the hazey stock one haha. Once I get the other sedan light, I'll have the passenger side p5 headlight up for sale. Also started modifying my hella 500ffs (Xmas present) to fit into the stock location. Now I just need a new bumper so I can mount my wrx lip also a Christmas present.
Mathmatically that would be awesome but will your P5 have the horsepowa and aero to reach 194mph? That's a pretty lofty goal, mate. But I hope she reaches it! When is that top speed day in Texas you're planning on?
