Yaggie1 said:Just slapped in the new Tribute windshield nozzles, easy a pie. Got the SLS motor mount today too. Probably do that on Sat when I install the new sway bar
how much were the nozzles? did you just get them through mazda or what?
FrolessWonder said:rather than shoot two streams of water, they mist over the whole windsheild. They seem to work a lot better, i put mne in last week.
amsgator said:is there a way to angle the beam of the fog lights? someone told me there is a little plate inside the housing that you can move to angle the beam parallel to the ground or into the ground. anyone done this?
JoshP5 said:You can aim them by loosening their mounting bolts. You can also bend the little shield that covers the top half of the bulb to alter the beam pattern "cutoff." But no matter what you do with the stock fogs, they still suck. Aftermarket FTW!
i cant unbolt my fog lights, the nut is stuck, and im afraid that if i try to get it off something will break. any tips?amsgator said:i just want them aimed off the ground. and i'm not gonna spend money just for fogs...i dont see a point, i dont use them in the fog since we rarely have any...so its not a big deal. i'd rather spend money on other stuff...like the header i am about to get. just dont know if i can wait on the motor mount(s) or not or if i need them immediately
BadKarma said:New rims looks great FrolessWonder... You need to submit your car for ROTM! I'd vote for you for sure!![]()
redpr5 said:i cant unbolt my fog lights, the nut is stuck, and im afraid that if i try to get it off something will break. any tips?
How are you guys taking out your fogs???amsgator said:try wd 40 or pb blaster and let it sit for a lil while then try again?
I just undo the front part of the splash guards (like 4 screws) bend back to get to the rear of the lights. Then there are three (10mm?) nuts that hold the fogs in the bucket. Undo the wiring plug and pull out the light. I can change both light bulbs out in under 20 minutes.amsgator said:i undid the bolt in the back and then the blue pin and they came right out. no sense in taking the bumper off....
http://www.mazdas247.com/forum/showthread.php?t=98860
i followed that when i did mine a while back
the very first time, I brought the whole bumper in the house and did it. LOL!amsgator said:it took me about 20 min to do mine the first time.
