JM1Protege
Made a list of things to do with my 64 rail dune buggy... I got some major plans for it this summer and ill post up some pics later.
awww they even match
So after a ~1000 round trip down to Florida over 3 days, I got to work on Monday and heard what I can only describe as a death-rattle in the Pathfinder. It sounded like someone had poured ball-bearings into my engine. I popped the hood and couldn't hardly hear the sound any more. So it wasn't detonation, piston slap, or any other number of bad things that could go on in the top end of the engine. Poked my head under the running board and sure enough it was coming from under the car. Rod knock doesn't sound like that (and I've heard rod knock before LOL), so what was it?
I did a little re-search and found out that it was likely just an exhaust heat shield, or a rattling cat. Got home and poked around and it looked like the noise was coming from the passenger-side exhaust resonator. I took the heat shield off, banged on the resonator again and it still rattled. *sigh* ok, so this has to come off now.
Once I got the mid-pipe out of the way and flipped it to help get it out from between the crossmember and the body, this dropped out:
I took it out of the garage to prevent further mess then up-ended it:
And the other pic of the damage to the cat itself:
I needed the truck to get to work today, so I didn't have time to drop the cat out to actually gut it, but I did take the time to fab up the ol' spark-plug non fouler trick (I <3 my drill press), so at a minimum it should clear up the CEL. It also explains the CEL (you protege guys know what I'm talking about
) And if I ever hear that rattle again, I'll know what to do to fix it. And if it ever happens again, I'm taking a long screw-driver and a hammer to the rest of the catalyst (gun)
Figured I'd share what I'd been up to lol
That is a common issue with Nissan cats. You should contact the local dealer to see if your Path has a recall for this. When I was running the parts counter for a Nissan dealer Sentra, Altimas, Maximas, and afew of the trucks had this problem.
Gotcha. I can't find any info on it, but I'll give 'em a call to see what I find out. Thanks for the head's up![]()
Back in the day that crap would get sucked up into the engine and sieze the engine.
Do not feel bad....
I got a coolant leak on my 1.8t. It appeared to be a hose but once half the car was dissected I realized that it was the o-ring behind the plastic fitting on the back of the block. So I went for the o-ring and nobody has it and the hose was a lost cause as well. So I went to the back and found a hose for a camaro that should work but no o-ring yet. WTF? Just for a coolant leak but on the plus note I am putting a "little American mussel" under the hood on my jetta.
Again, 2 month old post, but I see your 'clear plastic pieces' and raise you the following:Installed euro front clear parking lights, euro clear sidemarkers, euro clear rear tails, and euro clear 3rd brake light.
