hornsfan10609
Certified Mazda Tech
- 2003.5 Mazdaspeed Protege x2
Just wait until you crank the boost, I have never had any trouble with anything K-powered that didn't have forced induction.
Fill your new oem with silicon. It isn't the same but better than stock. if you want that solid and smooth inout feel you would really need solid. And upgraded shifter bushings too.
Of course I don't have a twm to speak for buy the mounts and bushings made msp shifter pretty nice.
I have to find it in the p5 no matter what I put in there heh.
215km trans vs 130km though.
Ugh, epic fail for replacing passenger side exhaust manifold studs. There's just not enough room in there to weld something to the stud to get it out. Might bite the bullet and take it into the shop to have them do it. Tempted to just buy a SteedSpeed and all the hardware and have a shop just swap everything out. We'll see though.
I pulled the radiator and used a center punch and a 5/16 drill bit to drill a slot in the end of the stud, then I used a flathead to back it out.
how do you like the crank pulley? is there a noticeable difference from the stock one?
If you remove the bracket for the PS pump you should have plenty of room.That's a good idea, although I have a MIG so I can easily weld a nut or end of a bolt to the stud and crank it out that way. I could also use a rotary tool (ugh, why didn't I think of it while the car was apart) and use the flat head screwdriver like you suggested. I'll be doing the timing belt/water pump in the spring so I'll re-visit the problem then.
My problem is more with getting the exhaust manifold out of the way enough to have room. This time I just removed nuts from the studs, disconnected the EGR tube, and just slid it down. Is there a way to fully remove the manifold and turbo as one unit so I have room to work? It's mostly the oil and coolant lines that have me stumped.If you remove the bracket for the PS pump you should have plenty of room.
