I checked every local auto parts store and all the local performance and dyno shops in my area. NOBODY HAS A SIMPLE 45 DEGREE COUPLER!!
would one of the pipe coupler at LOWES work out?.. the plumbing department has many different sizes and angles.
new shifting setup. Brand new 03.5 knob w/ a redline goods shift boot made out of bride material.
The hole(s) in the most current murdered FS are pretty impressive... I can look through the block and see sunlight on the other side of it...
Replacement engine is about to be set in... Waiting on my slim fans to get here...
Well yesterday I changed out my fubar'd primary o2 sensor, only to blow my engine fuse. Took me a while to find some fuses so I ended up going to sleep at 12:30pm and back up at 3:30 to get ready only to blow my hot pipe off merging into traffic. It also looks melted/cracked , so that should be fun. Should be headed to knoxville friday or ,.so hopefully I can see some msps along the way
Washed it. Buffed it with M205. Hand applied two coats of M26.Somehow managed to knock off the rearview mirror while moving it to clean off the window.
FMIC timeWell yesterday I changed out my fubar'd primary o2 sensor, only to blow my engine fuse. Took me a while to find some fuses so I ended up going to sleep at 12:30pm and back up at 3:30 to get ready only to blow my hot pipe off merging into traffic. It also looks melted/cracked , so that should be fun. Should be headed to knoxville friday or ,.so hopefully I can see some msps along the way
wait you still have the stock plastic SMIC pipes?
