hornsfan10609
Certified Mazda Tech
- 2003.5 Mazdaspeed Protege x2
Alright I have a new cable and the drivers are installed and it still won't connect to the AFC with the key on and engine off. Will the computer not connect if it is running Vista?
			no it won't. you need XP.Alright I have a new cable and the drivers are installed and it still won't connect to the AFC with the key on and engine off. Will the computer not connect if it is running Vista?
So on the fuel map A I need to change every 0 value to 10? For the whole grid?Well, the tuners express job is to manipulate the MAF signal being shown to the ECU, so if I were you, I would flash a tune of strait "10"s into the tuner. This should then effectively be doing nothing... and if you still have a problem, then you'll at least be able to narrow it down. Until you get there, you're going to chase your tail. If that clears your issue, then you can move on to the superstock map, and then start working out your AFRs from there.
i want to "like" this.Alright well I set every value to 10 and the car is running without fuel cut, it's a little rich in the 9s AFR wise but i'm extremely happy to have it running like it should.
I really appreciate everyone's help
Right on!
Now that you know how the software is setup you can do a little tuning to lean it out where you need to. That's the beauty of the SSAFC, very user tuneable.
Thanks I really appreciate it everyone. I'm still not clear on how to make a map. It's running a little lean in boost unless I go wot when it
Hits 9.0-10.3 or so. Still feels smoother than before. Can't wait to get a tuned correctly. Need to connect to the WB to datalog next.
Yeah it's running on vista. I will try to make a map, probably basing off of someone else's map at first. Although all the maps I download off of that thread don't load right on my computer they are blank when I open them in excel
You dont open them in excel, what you do is download a map from the thread, like the superstock map, and save it to your desktop for example.
Then close everything out, open the R4 software, once that comes up, hit file->open customer. Then using the box that pops up, select the file you just downloaded on the desktop. It should then have opened the superstock map, once you have that up, click on maps->fuel maps. A fuel grid should pop up and in the upper left of the fuel map, there are 2 buttons you can click. The first one on the left is to download the map from the car, the one directly next to that is to upload a map into the car. Connect to the ECU, car on engine off, and then hit the upload map to car. It'll do its map A loading, then Map B loading. Once its done, REMOVE YOUR KEY FROM THE IGNITION, and let the car sit for 30 seconds before you start it, if you dont, your car will throw a CEL.
Hope that helps
I never didn't want to be friends, lol. I was just frustrated the car didn't run right. It's my own stupid fault for not waiting to install it correctly I just didn't have time to set it up properly on my computer but now it's good and hopefully I can tune it to run much better.Glad you got it to work. what "justanothermp5" mentioned about is pretty accurate.
Hopefully now we can be friends.
