sounds like a worthy product. pardon the dum question, but how are you notified when timing is pulled? do you just feel it or what?
its got a display for KR, but if its dramatic enough to blow the engine at 13 lbs, I'm betting you'd feel the car suddenly have no balls too.
new front brakes and rotors, on to the rear
yeah, they look retarded al chrome, so I'd paint them black...but they sound good.
Would I just need to tap the + lead from the stock horn harness and wire that to these?
yep, the relay they give you wont really be needed, just buy a few extra fuses for cause i popped my fuse a few times like a dumbass
should I just put in a 10 amp fuse instead of the 5 thats in there?
happen to remember what color the stock + horn wire is?
I got some of the Hella horns from autozone, (was looking for the Blazers because they were orange, but they didn't have them in)couldn't really find anything else around here, and the Hella Supertones were way to expensive I thought for just horns, but the Blazers have the grounds running to themselves kind of, it's hard to explain, but they have the instructions with them and they are red on the outside, but you have to set them up backwards to make them fit up front, at least where I mounted them, I put one where the stock msp horn was, and the other on the opposite side so that it's like a mirror image of the other side for most part
they sound great, and I just tapped into the stock horn wire and ran it to the other one, haven't popped any fuses yet
http://www.autozone.com/autozone/accessories/Hella-12-Volts-400-Hz-low-tone-and-500-Hz-High-tone-red-plastic-trumpet-horn-kit/_/N-25ki?itemIdentifier=341083&_requestid=1455785
