Just to be clear, I put the EPB on, car in drive. Let off the brake, idle increased. Depressed brake pedal, idle dropped.Thank you! Ok so this goes deeper than a brake booster vacuum leak. I am determined to figure this out!
Good question!... I'm going to check those again tomorrow, I had seen the short term showing -4 or -7 percent at one point but don't remember exactly both readings.how are the short and long fuel trims?
Yes that's exactly the scenario TY!Just to be clear, I put the EPB on, car in drive. Let off the brake, idle increased. Depressed brake pedal, idle dropped.
Oil analysis to check for potassium.At this point what would you do next?
Ahh, to indicate the presence of coolant.Oil analysis to check for potassium.
1700 miles is a very short interval. It'd be great if your sample yields no potassium/sodium. If the values are high, then you can address the problem. Can you check under the rad cap too?Ahh, to indicate the presence of coolant.
My last oil change was at 34,500 miles and I'm currently at 36,200 miles. Is that a long enough period to show results? The coolant reservoir also shows coolant below the low mark. Halfway between empty and low.
I'm wondering if a compression test of each cylinder would be in order here.
