oh, forgot to mention...as of last night my Greddy Full auto TT has decided to work properly again. For a while it would not allow me to select different options nor would it store the saved run time on the car was started from the last time...
now it works perfectly after i messed with it for a couple seconds lol
No I need to find out what color the speed wire was again and finally hook that up lol
Wife borrowed the car, and now it's idling oddly. RPM will dip at a dead stop occasionally, and I've had it stall while rolling in neutral. WTF did she do to the love of my life?
what are you doing to the poor thing? :)
well after having the bearing explode in it not too long ago i changed the gearset and case with another one that was sitting around...repaired a broken bearing and swapped another bearing from my gear set...well i should have replaced all the bearings because there is another bearing that is bad so the trans had to come back out and i gotta go back through and change more bearings
doh! at least u know what it is, and don't have to spend alot more.
anyone know if lined vaccum lines have any advantage over unlined ones? i am buying vac lines and they have lined and unlined
painted calipers red! check it Front
