bradboyd80
- '12 Velocity Red MS3
^ nice one! i had BCs on my MSP, but went with H&Rs this time. how much are you dropping it?
Coilovers or springs? I think that's going to be my next mod (after the dp).
coyfish: quick steps on spin on kit install
- dump oil from sump
- at the top of the oil catridge housing, feel for a 15mm nut (loosen until fingers can undo) can completely be removed later
- theres a sensor that needs removing from the catridge housing (green clip) with a wrench, remove the whole piece from the catridge housing (unclip sensor + wire later or before to ease re-install on spin on housing)
- remove 4 x 10mm bolts from catridge housing to engine (have towls/rags around as a bit more oil drops from here) 1 of the bolts is a bit hard to get at but do-able.
- add spin on housing and fit everything up and dont forget to add oil
i took my time and had to go up the road to get a shorter 15mm wrench but it shouldnt take too long to do
i also added a fumoto oil drain valve, required an extension piece to clear sump (from fumoto also) - so now even easier oil changes.
bradboyd80: inlet is fairly easy once you've done it the first time, more room when you disconnect battery and remove it. just take your time like i did, just a pain to work on this car with little room
id call myself a noob and I attempted inlet and got it in, few months ago I fitted up a CS downpipe and PG manifold too all by taking my time
Got it. I'm leaning toward the BC's, or a set of springs. Those H&R's are pricey.
trying to get the sri on, can't get the damn elbow loose from the OEM elbow, is there a trick?
+1 on BC coils! I love mine, build quality was more than I expected
down side to BC lets cut our towers
^ how long have you had them on for?!
my BCs have been on for 20k, with no issues. no cutting either, but mine are 1st productions w/ no camber plates up front. thats why mine can go so lows
