elderlycoffee
- 2007 Sunlight Silver mazdaspeed 3
I washed it and cleaned the inside.
Rotus8 said:Today, at 4000 miles I rotated my tires. During the roatation I measured the tread depth. The front tires have .17" left and the rears have .29". This measurement is to the base of the tread groove, not to the wear bar, so usable tread is about .03-.04" less.
The specs from Brigestone for these tires is .3125" new. So, 45% of the tread is left on the front and 83% left on the back. Assuming I manage to perfectly balance when to do rotations so all four tires wear out at the same time, I have a total of 56% of the tread left. This means I will need new tires at about 9090 miles.
A set of four REO50As costs about $896 installed including shipping, mounting and balancing. So, the cost per mile for tires is $.10 per mile.
By comparison, gas at $3 a gallon, 22 MPG is $.14 a mile. At least tires are not as expensive as gas, but it's close.
jbiird317 said:When i got my stock tires put on my new wheels, the tech rotated the tires for me. He told me that the fronts had about 50% less tread than the rears (at 5500 miles). He accused me of having a little too much fun peeling out at stop signs, which may or may not be true, but I don't do burnouts or anything stupid like that. I think generally these bridgestones are not a very good tire. (poor quality and overpriced) When these are done, I plan on upgrading to something that has a better track record for tread wear.
Your tires are good, high (over) priced yeah, but far form being a bad tire. If you go to something with a longer tread life expect your performance to go down a little, easier squeeling on turns you took easily before and your tires will break loose a lot easier. After you get new tires put on I highly recommend you go to a autox and find the limits of the new tires it will save you from finding it the more expensive way.jbiird317 said:When i got my stock tires put on my new wheels, the tech rotated the tires for me. He told me that the fronts had about 50% less tread than the rears (at 5500 miles). He accused me of having a little too much fun peeling out at stop signs, which may or may not be true, but I don't do burnouts or anything stupid like that. I think generally these bridgestones are not a very good tire. (poor quality and overpriced) When these are done, I plan on upgrading to something that has a better track record for tread wear.
Velocifero said:Your tires are good, high (over) priced yeah, but far form being a bad tire. If you go to something with a longer tread life expect your performance to go down a little, easier squeeling on turns you took easily before and your tires will break loose a lot easier.
and that was with taking our time and a little trail and error, I think that can literally be done in 15 minutes now that I have done it and would have all my tools in teh right place not all spread out, including putting the car in the air. much easier than the protege thats for sure.Kosh said:With some help from Velocifero my AWR motor mount went in today in just around 30 minutes.
I like the performance of this mod maybe better than the CAI. It gives a much more enjoyable ride, and shifting is a lot smoother. I love my car 2x more now with the mount. Never thought it would make that much of a difference but it is definitely noticeable.
protege garage is the roxxxx!!!!
17 and 19 mm sockets and airtools made it easy. Torque wrench to finnishreme055 said:what do i need to do the install of the motor mount
not unless you have one easily, we did it my driveway on one jackstandreme055 said:do i need to lift it or no?
wrigh003 said:Now I am going to go lurk the audio forum and see if I can find the best/cleanest way to install my Ipod.
