Pulled the NOS bottle and brackets out of the trunk..
Nice, I remember having a NOS setup to spray the intercooler. I think it was more for a bling factor at meets now that I look back on it.
I have the same headunit! its so awesome!
The service manual. No need to remove the exhaust, but it's so much easier when you remove that bracket (especially when you are doing it for the first time).Are you using an instruction manual? Don't waste your time removing the exhaust or the bracket that supports the IM. You can get to all the bolts and remove the starter while leaving that stuff attached.
Yeah its great!, the sound is so much better and clear and the settings are so cool and specific in what you want to EQ. The color changing is also a plus
Was able to turn the engine over for the first time in almost a month!![]()
Starter died. Using a 626 starter now.
Latest; greased rear sway bar bushings, regapped my spark plugs to see if I get better spark, new spark plug wires, new headlight bulbs (GE Nighthawk Platinum), replaced rear passenger taillight, replaced a thermostat, fixed both my stock and aftermarket gauges as both weren't working, replaced my "ghetto-rigged" front RacingLine Performance endlinks with true front endlinks from the same company and put in some HPS pads in the rear to match the front while doing my bi-annual brake maintenance.
Oh, and cleaned up a used EGR I bought from DubbyDoo to put in the car soon as I'm pretty sure mine is pooched.
