Components Covered
Rotary Engine (for RX-8) Rotor Housings, Eccentric Shaft, Side Housings, Stationary Gears, Rotors, Main Bearings, Tension Bolts, Intake Manifold, Front Cover, Flywheel, Oil Pan, Oil Pump, Oil Pump Chain, Metering Oil Pump, Engine Mounts, Gaskets and Seals.
The following Rotary Engine components are covered for 96 months or 160,000 km: Rotor Housing and all internal lubricated parts, oil pan, oil pump, water pump and gaskets, seals and gaskets.
Reciprocating Engine (for all except RX-8) Cylinder Block, Head and All Internal Parts, Timing Cover, Gears, Sprockets and Timing Chain or Belt, Intake Manifold, Flywheel and Pilot Bearing, Oil Pump and Chain, Valve Cover, Oil Pan, Oil Cooler, Engine Mounts, Gaskets and Seals. The following list of items are included on 2009 and newer models: Exhaust Manifold, Turbo Charger Housing and all Internal parts, Supercharger Housing and all Internal parts, Water Pump, Thermostat, Fuel Pump.
Transmission/Transaxle Trans. Case and All Internal Parts, Torque Converter, Trans. Mounts, External Oil Cooler, Gaskets and Seals. The following list of items are included on 2009 and newer models: Transfer Case and all internal parts, Clutch Pressure Plate.
Drivetrain Differential Housing and All Internal Parts, Drive Axle and Constant Velocity Joints, Propeller Shaft, Centre Bearing and Universal Joints, Internally Lubricated Bearings, Boots, Gaskets and Seals. The following list of items is included on 2009 and newer model: Front Hubs and Bearing (FWD transaxles), Manual and Automatic Hub (4X4), Rear Axle/Hub Bearing ( RWD and AWD only).
