- Charlottesville
- 2016 CX-5
Had some Pirelli Cinturatos installed last week. I hope they will wear longer than the OEM Toyos. I only got 25K out of them.
I don't think the OEM tires are really going to last long. I'm at 23.9K miles and my tires are pretty worn now. I'm most likely going to replace it with Continental TrueContacts. Let us know how you fare with the Cinturatos.Had some Pirelli Cinturatos installed last week. I hope they will wear longer than the OEM Toyos. I only got 25K out of them.
Check the UTQG (wear rating code) on your Toyo's sidewall. It's about 280. That's why they don't last. Replacement tires generally run 600-700; so they wear about 2+ times as long.I don't think the OEM tires are really going to last long. I'm at 23.9K miles and my tires are pretty worn now. I'm most likely going to replace it with Continental TrueContacts. Let us know how you fare with the Cinturatos.
Oh I didn't know it was only 280. That's like wear rating for a summer tire. In any case, my experience with Mazda OEM tires are that they will be worn out by 25K miles, so it is not really surprising that they won't last long. I've replaced the OEM tires on my previous Mazdas at around the 25K mile mark.Check the UTQG (wear rating code) on your Toyo's sidewall. It's about 280. That's why they don't last. Replacement tires generally run 600-700; so they wear about 2+ times as long.
Chicken wire?
Tada, Maxhaust soundgenerator (Original Audi SQ5) with Maserati gts V8 soundmodul + some alu buthyl dam work-now I will figure out a nice setup with theire app the next days-3 Profiles to save will give me some fun
There are already some videos on youtube about this product to give you a idea how it sounds
Cheers 101
Hey I can sell you an axleback exhaust designed to mount a turbo.. just throw a junk t3 turbo on it and you will sound like a diesel.. no oil supply or anything needed since just for sound
Looks good... And A nice looking Plate too.. (first)
That last paragraph is hella confusing. I put in a new filter that was dirty. But there was a new filter there. So why did you in stall the dirty, yet new, filter?Opened up my new to me 2014 2.5 GT to do the front and rear differential fluid, not knowing what sort of history the car has had. I was pleasantly surprised to find very clean fluid, but filthy magnets.
However, I did find some significant seepage from the engine dripping right where it meets the transmission, but didn't get a good look to see if it was coming from higher up. I'm still within the factory drivetrain warranty, so I emailed my local dealer with a picture and they said all should be covered under warranty, so I've got an appointment in a short while to see what happens next.
I also put in a new cabin air filter that was pretty dirty, but did find a practically brand new engine air filter already installed.
One is cabin, one is engine. Not sure about the installing a dirty filter though. LolThat last paragraph is hella confusing. I put in a new filter that was dirty. But there was a new filter there. So why did you in stall the dirty, yet new, filter?
