what harness do i need??
pbot
I just bought the Pioneer p3200bt, i am trying to figure out what harness i need to buy, so i don't need to cut off the original harness incase in need to put it back.
I talked to some people and they said buy the Metra 707903t.
I looked at this harness and it says it just makes it possible to change the clock once the new system is installed.
I looked at the Ma03B but it says its not compatible with the 08 CX7.
I just don't want to cut off the existing harness if i don't need to
Can someone help?
either one of those should work. what you are reading about the clock is that since the controls are tied into to the radio harness, it gives you the option to connect your stock radio without re-wiring. at least thats what I remember.
OK thanks, so i still need to cut off the original harness? thats what my biggest issue is, i am going to pull it all off and see what i'm dealing with.
thanks again
no. thats the point of the harness, it attaches to your original plug, then you wire that into the new plug that connects to your new radio.
