Are you basing that off of fact or an assumption? 3rd gen Supras, 93-95 Imprezzas, 4th Gen Supras all came with 19mm valves and none suffer from "turkey" neither with the factory valve nor with our upgraded units. I've personally run the OEM 19mm valve on a TT Supra at 22psi and over 400 wheel horsepower so I'm not convinced that 19mm is too small.
There may be something unique with the MSP that going to the larger size corrects but I would be curious to see if it has more to do with running a new reference line or just ditching the diaphragm valve. Or both.
It worked for me.
