What all do I need to run a TPL91-B turbo?
this one? its a bolt on. And it has the airflow volume is 55 cubic meters per second. Very Nice upgrade.
well it all looks good on paper, but what should i expect for a spool time?
It should start spooling roughly around 40K rpms! The only problem that I see happening is even with doubled valve springs is.... that I will more then likely still float a few valves at that rpms and the stock gauge cluster doesn't go that high so it might break as well.(drive)
did a fast calculation, dunno if its correct,
55 cubic meter/second = 116 538.398 5 cubic foot/minute
assuming 10lb/min of air = 144cfm
116538.4 cfm = 8092lb/min
Our engine flows 14lb/min of air @ 6500
so....our basically we need our motor rev up to
8092*6500/14 = 3757000 RPM which is much faster than 40k HAHA
correct me if its wrong...
yeah... someone has way to much time on there hands.
Latest posts
