Weird creeking noise!
importMP3
About 2 days ago I was driving and all of the sudden I started to hear this weird noise from the right front wheel well. It sounded like a creeking noise, or maybe something was rubbing. It went away after awhile, but then came back again today. I installed ground controls about a month or so ago, and lowered it 2 inchs. Has anyone else with ground controls experience it, or has anyone else had this problem. I've searched my wheel, and my engine and could find nothing wrong.
Thanks
Sup Bro,
Well the same thing happened to me after installing the ground controls. The soudn didn't start until a few days after. It turned out to be a plastic washer/spacer was missing atopt he aluminum tophat that went on top of the springs. The plastic washer didn't come with the springs, it was a part left over from the stock spring set.
My advice to you is get a floor jack or lift and with both the front tires free from the ground feel up above the spring and see what you can find.
If you have any Q's gimme a ring,
602.525.2808
This happens to my friend (Jag61180) sometimes. The spacers on top of the coil-over perch becomes unseated. You have to jack-up the car, and re-seat them if this is the problem.
