Weak Vibrations in Acceerator & Brake Pedals?
m3w49
I just started noticing some weak vibrations in both my accelerator and brake pedals whenever the accelerator pedal is depressed, even at low speeds. It's obvious if I put my left foot on the brake pedal while driving on the freeway. I also noticed some slight vibration in the steering wheel as well. I was wondering if this was normal and (maybe a result of bad roads?), or If I should bring it in to the dealer and have it checked out.
Edit: this is on a 2014 CX-5 GT FWD
Perhaps some wheel is out of balance? I don't have any vibration like this.
Yes, take it to your dealer.
If it vibrates when you brake, you may have a warped brake rotor. I had that issue with my previous car (mazda 5).
