Water pump problems
I replaced my water pump a while back, and it started leaking at the inlet within a month. I must have messed up when I did that gasket. I need to fix it, but I don't want to have to go through the whole process of re-doing the water pump install. It looks like if I remove the PS pump I would have easy access to that bracket, but is this the best way to go or should I just pull everything off and start from square one again?
