water and alternator pulley
mazda32008
mazda3i 2008 M/T!
i will be changing my water and alternator pulley soon and putting a rear anti roll bar on stock suspension...i don't know if that is a good idea though. Will i have any problems with changing those 2 pulleys? or with putting a anti roll bar on stock suspension?
Nope. Go for it, take pics, and enjoy, lol.
I've got the Alt pulley i'll probably put on tomorrow and I've had the MS rear sway bar on for months now. Enjoy!
never mind stock suspension im mazdaspeed springs and lowering it. Only prob is im rolling on steelies.
I changed my water pump pully/ alternator pulley and crank pully. Is totally not a bad idea, you willl notice a gain in the low-mid range. Be carefuly with the belt re-install, because I use change my crank pully as well, I have to change my belt to a longer one. Otherwise the belt will be too short and will put too much tension on the tensioner. I am not sure without the crank pully.
well i won't be doing this my self so when i get my springs in i will prob take it to my mechanic to install everything all at once, only thing is i am scared about the pulley thing. I don't want the timing to be ****** so when you change the pulleys does the crankshaft pulley get touched? What is sparkboost system...are you spraying?
Any pictures??
