I just recently installed a FMIC and 3" downpipe-back exhaust. The first day it was running fine. Then the next morning, I started to have major boost spike issues. First gear, the boost spikes all the way to 15psi. Then all the other gears started to do the same thing. Now in first gear, on full throttle, the car sputters very loudly and still spikes to 15psi. I disabled the EBC and it still has the same problem.
Also, I noticed something when I checked under the hood. While under the hood, I revved the car and I saw white smoke come from under the heat shield. Then I noticed that there was a sound as if the exhaust is leaking.
My questions are: Could it I possibly have and exhaust leak? Would I need to replace the stock wastegate to stop the boost spikes?
NEED HELP RIGHT AWAY!!!
