I am staying in an gated community apartment. I don't have a luxury of using hose and rinse ( California is a drought place
) (bang)
2 bucket (naughty)is enough for CX5 ?
So the best option is to go to a car wash ? But after hearing some replies I think their brush is going to create scratches on my new car's paint
confused !!
Since you're in an Apartment I would use a rinseless wash product. There are many good ones available such as Optimum No Rinse, Meguiars D114 or D115, Ultima Waterless wash + concentrate, Duragloss rinseless wash, blackfire wet diamond rinseless wash, etc. All of the ones I listed are available thru amazon and most are available thru sites like autogeek.net and autopia.org. The way a rinseless wash works is that the "soap" encapsulates the dirt when you wipe the car with your microfiber towel/wash mitt/sponge and then is released into your dirty water bucket. After wiping one panel or section of a panel use a microfiber towel to dry that panel and that's it. No need to have a hose and rinse the car off after cleaning.
The two bucket method can be used with rinseless washes if you are using only a few towels or wash mitt or sponge to clean. Lots of people will use a grout sponge for doing rinseless washes, the Proline sponge from Lowes is a forum favorite and it's cheap. The idea with a two bucket wash system is to fill one bucket with water and add your wash solution, this is your clean bucket, the second bucket gets filled with just water and is used to rinse your wash medium after cleaning a section of car. This is to minimize the amount of dirt and grit that gets into the "clean" wash solution. Grit guards are recommended for the bottoms of your five gallon buckets so the dirt can settle to the bottom with out being re-agitated into the water.
To do a rinseless wash you would only need about 2 gallons in your "wash" bucket with about an once of rinseless wash solution. If you use multiple microfiber towels you don't need the rinse bucket as you'd have enough towels, one for each section or so. About 5-10 towels is usually enough to wash the CX-5. Fold your towels into fourths and use a new side of the towel for every couple of wipes. Search Youtube for videos showing you how it's done.
Some people have told you don't need to wash the car, or just take it thru the brush-o-matic car washes or use the DIY car washes and the foaming brush they have their. You can do those things if you want, you're car is not going to fall apart from doing so. Everyone is going to have their own definition of what a clean car is. For me, its a car that is not only free of dirt but also free from swirls and scratches. The above methods of washing a car will induce swirls and scratches into the clear coat that can only be removed form polishing and or compounding. The Brush car washes are rarely cleaned so all the dirt and grime is stuck on them and rubbed all over your car. Do you really want to be the next in line after a pickup truck just went thru that was full of mud? Same goes for the brushes at the DIY car washes, you never know what is in the brush or how clean that brush is before putting it on your car. Some people think hand washing is a waste of their time and don't care about minor swirling in their clear coat, and that's fine, it's why thousands of car washes are in business all across the country. I enjoy washing my car, it's relaxing for me.
Decide what you want and what you want your cars finish to look like. If good is good enough then go ahead and do any car wash you want. But if you want to make sure you are minimizing any chance or scratching the finish then a hand wash is you best option. Hand washing allows the most control over the process. Just remember that taking care of your cars finish should be therapeutic, not the reason you need therapy! If you start reading detailing forums you might start to think that your car is a fragile, delicate thing that needs constant attention, it's not and it doesn't but a proper wash technic will help ensure a better finish on your car.
Here's what I do for my winter washing since I don't have a hose in my garage and I'm in Wisconsin so a hose outside would just be frozen. My garage is attached but it's not heated so on days when it's sunny or at or near 32 degrees out side the garage is usually around 40 or so. I mix two ounces or Optimum No Rinse wash and Shine (ONR) with 3 gallons or warm water into a 5gal bucket. I use a higher concentration because out water is very hard. In a separate bucket I fill with just plain water about 3 gallons or so. I take my 5 Rag company Korean edgeless Microfiber towels and soak them in the ONR solution. In a 1 gal garden sprayer I have mixed an ONR solution that I use as a presoak on the car before cleaning. I spray the panels I'm about to wash with the sprayer to help loosen the dirt and provide more lubricity. I take one of my towels, fold it into fouths and squeeze out a bit of solution so it's not totally dripping everywhere. Using straight wiping motions I wipe a panel at a time working from high to low, front to back. Roof, windows, hood, fenders, front bumper, doors, rear hatch and glass. After every couple of swipes I turn the microfiber to a clean section. When all sections of the towel has been used I dunk it into the rinse bucket and leave it there grabbing a new towel from the solution bucket. After I've "cleaned" a panel or section of a panel I use a larger microfiber towel, waffle weave, or thicker nap, to dry that section right way. I do this over the entire car until it's clean. All told it takes me about 30-40min to wash this way in my garage without any hose. When all is done I empty the buckets and throw the used towels in a wash load with dye and perfume free detergent (free and clear) then dry them in the drier with air only. Microfiber towels should be washes separately with no fabric softener and very low to no heat. If the car is really dirty I will go to a DIY wash place and use the high pressure rinse to get most of the grime off first. It only takes a few minutes and doesn't cost much but then I do my rinseless wash as described. Sometimes you can even bring your buckets and stuff and do your rinseless wash in the DIY bay if it's not to busy and the place allows it.
This is just what I do for my car and it works well for me. At the end of the day, do what you want. And have fun.
