Not trying to be a dick but how can oyu tell it was there DIffs when they said they had a blown trannyBlkZoomZoom said:2 out of 3 posted were blown diff's. And 1 wasn't determined....thus supporting my previous statement.
Ok but theres atleast one that wasnt due to the MSP LSD cause it was a Pro ESBlkZoomZoom said:I have the second version of the diff. in it now. No modifications.
Oh, I'm not a dick, I'm a "tool". lol And if you read the description of their problem and had a good understanding on how transmissions worked you would realize this was what happened also.
The blocks we get are fully checked over to ensure they can be used.All blocks are magnafluxed and checked for cracks.Our motors are custom built to your needs.So i you want a .020 over or a lite hone we will do it.Same goes fr compression, it's s custom motor built to your likings.Core charge is $500.wicked said:our tranny's are a lot stronger then people are making them sound,just cause we have a LSD that likes to break.
MAM-
any way,aboout those short blocks.
were the blocks just OE,then machined,or did you guys have them checked for week spots,cracks,or thin spots?
also are they bored over?if so,then how much .20?
what about compresion ratio? the OE is 9.1 to 1,can I get 8.5 to 1?
how much do you guys charge for a core,because I want to keep mine.
are you re-milling the top deck,if so are you going to componsate for the ratio change?
sorry to bug with all these questions,but if I'm going to pick one or two of these up from you guys instead of me getting them done here I want to make sure I getting exactly want I'm looking for.
thanks
Mental Addiction said:The blocks we get are fully checked over to ensure they can be used.All blocks are magnafluxed and checked for cracks.Our motors are custom built to your needs.So i you want a .020 over or a lite hone we will do it.Same goes fr compression, it's s custom motor built to your likings.Core charge is $500.
As for re-milling, Yes, the block is square decked and quench height is set.Compression is already figured in when we order the pistons.
How on earth could you do it yourself unless you have a machine shop? There is a specific machine for each process and they are super expensive! If you want just a plain ol' rebuild, get the Haynes manual (I got it). It's a great how-to with pics and specs.spacemonkey said:Seems like someoen should do a nice little write up for those who want to do it themselves.
yeah, I could do a write up on it, pretty much tell you everything Beau does to it, but you are still going to end up costing pretty much the same he charges... see, there is a LOT done to this block for prep, and of course ATLEAST $1500 in parts alone, not including the block core, not including any machine work (which is expensive), and not including all the time required to do it. which I've been tooling on my block for a while. damn casting flash...spacemonkey said:Seems like someoen should do a nice little write up for those who want to do it themselves.
