walbro fuel pump
Shane5425
Contributor
2011 Mustang GT
Witch model pump will be a direct replacement for the one in my tank, i really dont want to put an inline one.. ?? is it the rx7 model that replaces ours in the tank??
miata.
got it in, installed it, all problems went away... car holds 12:1 all through boost... whoo hooo
Nice! Didn't even begin to think of what model Walbo unit I would need for my kit, when I get it of course! Where can the unit from the Miata be found?
Well I had gotten mine from Beau, that seems to not be a very good idea at this point in time, so I would contact Ken from protegegarage.com.
He can confirm but this should be the right part:
Miata94-97255LPH HPGSS342-400-848
david_shea said:
hey i got one from protegegarage.com and it doesnt match up, do i have to modify it? i have a mp5
yes. you do. if you're talking about the walbro in tank, you have to take out this little rubber piece, and basically SMASH the plastic holder on it...kind of hard. but, you can do it.
easier way to modifiy it, that plastic retainer clip, get a dremel tool, and notch it out.. that was the only modification i had to make, took abotu 10 min
what was the problem you were experiencing??
was running to lean... under 5psi was ok, after that, would run 15:1 air fuel ratio... lil pump couldnt put the volume of fuel i needed
