Vibrant Exhaust Install
This might help a little it was a write up I did a while back
I also have the Vibrant exhaust system and everything Mr. Digger is saying is accurate. Some of the problems I incountered are; stock exhaust removal, two of the bolts were fused to the flange so I tried to dremel of the nut and ended up going through my 3 discs with no luck. So I decided to use the hack saw and cut the piping which took a little bit but it worked good. Just make sure that you cut on a straight piece not on a bend so a collar could be welded on IF you ever have to use the stock exhaust again. After the stock exhaust is out I bolted up the downpipe, and yes I used the bench grinder to grind down the collars on the stock S/J-Pipe bolts. The Piping on the Vibrant J-pipe is to big so grinding is a must. Next I bolted up the catback section which is really easy, use the Kartboy exhaust hangers(buy them in advance,you'll need them.) That's pretty much it, I did not extend the O2 wire myself I took it to a local shop and they did a cleaner job than I could have done cost $80.00 but that's cool.
Things I noticed after install; RATTLING, I had rattle coming from the muffler hitting this metal lip that is located, well right above the where the muffler would rest, I fixed this by putting a peice of foam in between the metal lip and muffler, seems to be working good. The next rattle I had was from when I installed the Kartboy shifter, it was hitting the heat shield, so I just bent the heat shield away from the shifter, all is good there. Finally the last rattle I noticed was in the cabin and coming from the rear deck where the fux speakers are, This can be solved by removing the plastic section and putting weather stripping in between the plastic and the metal. I used 7/16" weather stripping and it works good.
All said and done I would still buy this exhaust system, I wish I would have been more prepared but it's not something that's to difficult to handle though.The sound is a low pur at idle and a deep growl at WOT I guess is the best way to decribe it. I did notice a lot more pull from 4k rpms and up. If anyone has any questions feel free to PM me also. And for those getting in on the GB you won't regret it, it's an awsome exhaust system!!!!!!!!
Edit: Alright, screw the foam, just grab a pair of channel locks and bend the metal lip away from the muffler, works a lot better than the foam idea.
Thanks alot for the writeup silver.. I just got done installing the exhaust and WOW what a pain in the ass.
Without a torch i would of been at a loss... I don't really want to go through the whole thing but pretty much when bolting the front end of the cat onto the spipe the bolts are so close to the cat pipe that you cant fit nuts around them.. I had to pretty much rig it with small nuts and washers and have a tilt to the bolts. Tomorow im going to go to a place and get allen heads so i am tighter. After that it was easier until i had i everything bolted up. I had to go ahead and actually bend the whole muffler because it was slammed against the bumper and i dont want my bumper to melt. Then the shield under near the cat was touching the pipe so i had some rattling there. I took some of the c clamps i beileve there called and put them around the hangers and kept tightening them until there was about an inch of room between the pipe and the plate. I didnt need to do anything with the o2 sensor just cut the tie and wala. Doesn't sound like alot but it was very fustrating, but after turning the car on to here it made it worth it :)
Geez, I was bitching about the install, and I had it a lot easier than you did. I'm not sure what you mean about the cat to s-pipe part. Could you mean the j-pipe (that does go into the cat farther down), and where it bolts up to the s-pipe? Not being a smartass, just a little confused.
Oh, and I didn't know the wires could be extended until a couple of days after I did my install, lol. I did a beautiful job splicing and wrapping them though. My wires are also wrapped in hi-temp insulating tape for about 18" back from the 02 sensor.
The pipe that connects to the spipe or manifold whatever is up there is what im talkign about. Were the bolts like jammed next to the pipe? cuz I couldnt get the nuts around the bolts at all
Like right here? I had to ever so slightly dent the pipe in a bit, as well as tap the studs outward a bit.
pull those studs out and buy some allen head bolts. you wont have to deal with grinding or getting different nuts.
not hard bolt 2 nuts on the stud. one locks the other in place, one to turn the stud. probably like $5 tops at a hardware store.
And JDM Sam comes through with this information months AFTER I bought the exhaust from him! Kind of like "Oh yeah, you can extend the 02 wires". Thanks Sam! Way to be there for me! ;)
(lol)
I'll be getting this exhaust shortly, this will bolt up to the stock s pipe correct.
I'm getting the kartboy hangers also. I've noticed that most people recommend replacing the motor mount(s) also. Do I need to do front, back or both? Durometer?
it bolts up perfectly to stock S pipe. Highly recommend the hangar upgrade. I would change the motor mounts. Ill let the experts comment though on if you NEED to. It is a great upgrade, it puts more power to the ground.
